1Back to top Go down   89 K100RS starter issues Empty 89 K100RS starter issues Sat Mar 23, 2013 8:33 am
ridefar
ridefar
tried to start the rs and battery was weak. The starter stuck on.Disconnected the battery and charged it. Now starter engages when battery terminals are connected. Is this the starter relay?
2Back to top Go down   89 K100RS starter issues Empty Re: 89 K100RS starter issues Sat Mar 23, 2013 8:47 am
'fraid so, ridefar,
It sounds as though the relay contacts have welded together.
3Back to top Go down   89 K100RS starter issues Empty Re: 89 K100RS starter issues Sat Mar 23, 2013 8:47 am
twincarb
twincarb
It very much sounds like it is.... a quick way to confirm is with the battery disconnected lift the tank and take the cover off of the relay box. If you tap the relay it should break the contact that has been made. You can then reconnect the battery and mysteriously everything is fine....
Don't be fooled into thinking this is a fix it's more of a get you home fix! Realistically the Relay will need replacing.
Yamaha Thundercat
89 K100RS starter issues 16904289 K100RS starter issues 169034
4Back to top Go down   89 K100RS starter issues Empty Re: 89 K100RS starter issues Sat Mar 23, 2013 9:26 am
JimK
JimK
Ridefar.
Get to tool kit.
Get the screwdriver out.
See the upper corner of the relay box on the right side. right near the end of the fuel tank.
Thump it several times with the butt end of the screwdriver.
Touch battery cable back to battery.
Hopefully this will work to free up the relay contacts and avoid having take things apart.
Worked for me.
Jim....Don't take the tank or anything else off before trying this.
Bought a new battery and have not had any probs since.
Last edited by JimK on Sat Mar 23, 2013 9:32 am; edited 2 times in total (Reason for editing : clarity)
'89 k100 rs se
5Back to top Go down   89 K100RS starter issues Empty Re: 89 K100RS starter issues Sat Mar 23, 2013 10:18 am
ridefar
ridefar
Thanks for your help, I'll check it out.
I imagine those relays don't come cheap!!
6Back to top Go down   89 K100RS starter issues Empty I have a spare for cheap Sat Mar 23, 2013 10:43 am
ibjman
ibjman
I have a "Well Used" working relay for sale if you end up needing one.
$15.50 delivered to your door
ibj...
