1Back to top Go down   Hello from Iowa Empty Hello from Iowa Wed May 08, 2013 9:09 am
mjydrafter
mjydrafter
Hi folks, new member here from Iowa.
Hopefully I won't be too much of an outcast here since I have a K75... Embarassed
I see you have a section for them, so hopefully I won't be killed and eaten for looking around. 🤡
Hello from Iowa 25650you guys have some great smiley's!
2Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 10:28 am
welcome aboard .....we dont bite ......erm ...much
good to see another member wih a k .....happy riding !
pics please ...(when you can )
3Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 10:31 am
Welcome to the Knuthaus good to have you along for the ride.
4Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 11:03 am
mjydrafter
mjydrafter
Pics:
Hello from Iowa 20130329_114224_HDR_zps5b259852
If you are members of motobrick or Advrider, you've probably seen it. bounce
The fairing is off of an R80 or R65 or R45 or something, it kind of makes it one of a kind.
I've been through about everything with it, even a dreaded final drive failure. Still have a bit of stuff to catch up on, but it's getting there.
Hello from Iowa IMG_6591
Hello from Iowa 61740
Still love 'er though. Very Happy
1986 BMW K75c
5Back to top Go down   Hello from Iowa Empty K75 final drive Wed May 08, 2013 2:01 pm
ibjman
ibjman
I have a used K75s final drive you could get pretty cheap and quickly if you have need for 1.
I also have the matching driveshaft, but I believe the U-joint needs replacement as it has a "tight" spot when moving in one direction. All used parts will show some spline wear. A lot of folks here may be critical of the spline wear being "sawtoothed". My inspection shows that the splines on this rear end are excellent.  The unit turns through by hand smoothly & has no loose backlash. The motorcycle had 80,000 miles on it when it was taken out of service.
You can have the drive & the shaft shipped to your door for $88. Via USPS Flat Rate box
I have a Paypal account
Hello from Iowa K75_ri10
Hello from Iowa Seal_s10
Hello from Iowa K75_ra11
Hello from Iowa K75_pi11
Hello from Iowa K75_sh10
Hello from Iowa K75_sh11
6Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 2:39 pm
Welcome too.
Its a good site and there is actually atmosphere here. Great technical stuff but also great meet ups, fun, smileys and things. Everyone is very helpful with parts, advice, nice photos and tales of the unexpected.
The K is good for many miles, be it K75 K100 or K1100. There are many who would prefer the K75, it is smoother at certain revs and of course lighter to move around, important considering the age range here is from 21 to 84.!!!! Certain mature members [hopefully me one day too] worry more about their final drive when one would expect them to be using zimmer frames.
Maintenance is easy with the advice from here.
7Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 2:46 pm
mjydrafter
mjydrafter
ibjman wrote:I have a used K75s final drive you could get pretty cheap and quickly if you have need for 1.
I
Thank you for the gracious offer, but it happened last summer and I was able to get it replaced.  Mine has oldster drum brakes, so I would have had to purchase all the rear brake stuff, and a new rear wheel.  I thought about upgrading to a paralever, but $$$ kept me replacing the unit, and reusing all my old stuff.
When I removed it the pinion nut was loose, allowing the pinion to move in and out in relation to the ring gear.  It still worked just fine, but made some "interesting" noises, most when decelerating.  Sounded like gravel, yuck.
1986 BMW K75c
8Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Wed May 08, 2013 4:24 pm
Hi & Hello from Iowa 177912
When I saw the pic of your rear drive, I couldn't see how it could have become so chewed up, so thanks for letting us know that the nut was loose..............Something else to check when doing a spline lube, eh?
Cheers,
9Back to top Go down   Hello from Iowa Empty another triple treat Thu May 09, 2013 7:35 am
mawhera
mawhera
Great to have more k75s on the rd, love to ride one one day. no outcasts here in my short experience thus far, two or three wheels / cylinders what the heck it k ing around the place. I'll try an empty rd pic from NZ balzed the last one up.
rick
10Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Fri May 10, 2013 1:32 pm
10-ring
10-ring
Hi
What part of Iowa ? I went to school in the northeast corner.
Lots of good riding along the Mississippi river there. Hello from Iowa 177912
11Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Fri May 10, 2013 4:59 pm
Welcome MJYDrafter. Plenty of K75 aficionados here, you're in good company. Enjoy the forum.
Hello from Iowa Ir-log1188....May contain nuts!Hello from Iowa Ir-log11
K75RTP - 1994
12Back to top Go down   Hello from Iowa Empty K75s, I have one Sun May 12, 2013 6:54 pm
tio Jaimito
tio Jaimito
MjyDrifter, Welcome to this great forum. If you get out to Chicago look me and my club up we can ride together.
Good to have another Midwesterner on this list.
Jim
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Hello from Iowa K100_m12
Hello from Iowa K75_po12
Hello from Iowa Basil_10
http://www.nachicagonorth.com
13Back to top Go down   Hello from Iowa Empty Re: Hello from Iowa Sun May 12, 2013 10:34 pm
dmanley
dmanley
Welcome.
Daryl
1985 K100RT
