1Back to top Go down   Hello all Empty Hello all Fri Jul 12, 2013 5:01 pm
thenorthernmt
thenorthernmt
Hi, Montana guy here, had my k100 for just over two years, although i've had some kinda bad luck with it. Bought it with an aftermarket shock with a stainless steal cable that ran to the adjustment canister. Well, i had been taking it apart and putting it back together as i was restoring/customizing it, and the cable ended up near the battery, and as i was riding it sparked the terminals, which created a fire. I've replaced most of the burned up parts that looked damaged, but I can't get it to run. It will start and then back fire. So far in an attempt to fix this I've changed out the injectors, and computer, but no luck. Any ideas on what to look into next?
2Back to top Go down   Hello all Empty Re: Hello all Fri Jul 12, 2013 5:51 pm
Beemer Wheeler
Beemer Wheeler
Hello Montana, and welcome.
Sorry about that battery fire.
It would be "normal" on a 787 nightmare liner, but on a K ?
After a few posts here you'll be able to post questions in the relevant sections of this forum.
But you might get suggestions here sooner.
Good luck on the fix job.
1986 K 100 RT "K-T" short for "Katie" 120.000 Km
   Hello all 2cr0y2r  Hello all 116p8ic
1998 BMW 318i Cabrio
2012 Yamaha YFL 381 (Flute)
2005 Yamaha PSR E-203 (Keyboard Synth).
2012 Yamaha 7 HP outboard engine
"Beemer Wheeler" Certified Brick Aviator since July 2013
Ham radio call sign HA5AH
http://h2fuel.mobi
3Back to top Go down   Hello all Empty Re: Hello all Fri Jul 12, 2013 8:37 pm
Hi there Montana Man welcome to the forum. If you put a post up in the regular part of the forum probably electrical you should get a good response as many of our gurus dont come here so may not see the post.
4Back to top Go down   Hello all Empty Re: Hello all Sat Jul 13, 2013 6:03 am
Hall sensor???
5Back to top Go down   Hello all Empty Re: Hello all Sat Jul 13, 2013 10:59 am
Beemer Wheeler
Beemer Wheeler
92KK K100LT 193214 wrote:Hall sensor???
Hello Hall ?
http://h2fuel.mobi
6Back to top Go down   Hello all Empty Re: Hello all Fri Jul 19, 2013 5:53 pm
Great to have you with us as above pop a post in the main forum.
