1Back to top Go down   Tire sizes Empty Tire sizes Wed Jun 04, 2014 7:15 am
87m6chris
87m6chris
On my 1990 K75 I have a 100/90-18 tire on the front and a
130/90-B17 on the rear, even though they are only 6 yrs old the side walls are starting to crack so I'm going to replace them.
Just wondering if I have to stick with these exact sizes or if I change them a bit like you can do with car tires?
Thanks,
Chris
2Back to top Go down   Tire sizes Empty Re: Tire sizes Wed Jun 04, 2014 7:28 am
100/90-18 or 110/80-18 front
130/90-17 or 140/80-17 rear
The 110F/140R combination was used on some of the later RSs on the same sized rims.  With the larger sizes you might be able to move to radial tyres.
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Tire sizes K-dogs10
3Back to top Go down   Tire sizes Empty Re: Tire sizes Wed Jun 04, 2014 12:56 pm
k75RT Keith
k75RT Keith
You can go up 1 size front and rear and they will still fit.  Your bigger limitation is the 2.5" / 2.75" rims that limit what you can fit on the rim
4Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 6:45 pm
87m6chris
87m6chris
Thanks Gents,  not many tires in our sizes anymore.
I'm thinking about this combo,
http://www.fsmotorcycle.com/tires/sport-tires/pirelli-sport-demon.html
Anyone using these?
Thanks,
Chris
5Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 8:33 pm
@AL-58 wrote:100/90-18 or 110/80-18 front
Will the lower aspect ratio front (110/80) end up with a smaller overall wheel diameter than with the 100/90?  I've problems with my front Avon 100/90 tire almost hitting the fender; I have barely 5mm clearance, even with spacer washers to raise the fork cross brace (K1100 Marzocchi stanchions). I have K1100 3-spoke 3X18 front rim so tire selection would be more varied than the K100 snowflake rims.
6Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 9:21 pm
@87m6chris wrote:Thanks Gents,  not many tires in our sizes anymore.
Anyone using these?
Thanks,
Chris
they work great chris
quite a few members have them on....road surfacing compounds differ across our country's  so you might find different wear rates and expected killometers- miles out of them
rob the lower profile does give a little more clearance
i notice that with the 140 on the back ( or even the 160 on the wide rim ) im doing 4100 at 100 kph ....where as with the 130 x 90  im doing 4k for 100 kph ...if that helps any (still confuses me though )
additionally i have slightly more lift off the ground on the centre stand with the wider profile tyres ....with the 90 sizes both wheels touch the ground ...just ...;.so just a bit of difference in overall diameters
hope that helps
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OTire sizes Au-log10
7Back to top Go down   Tire sizes Empty Re: Tire sizes Sun Jun 08, 2014 5:32 am
90% of 100mm = 90mm tyre height
80% of 110mm = 88mm tyre height
There's not much in it.
Tire sizes K-dogs10
