1Back to top Go down   City Case Piano Hinge Empty City Case Piano Hinge Thu Jul 31, 2014 9:56 pm
Since they only open about 30 degrees and all the hinge has to do is support the weight of the outer half, this probably isn't as good a mod as doing it for the larger cases. That and the fact that a plastic hinge only costs $5 from BMW....
But I decided to do it anyhow.
City Case Piano Hinge City_c11
2Back to top Go down   City Case Piano Hinge Empty City Case Piano Hinge Fri Aug 01, 2014 7:54 pm
Ha that should make it slide better on the road when it comes off.
I've actually just removed a set of piano hinges from and old set and replaced with the plastic strip as the hinges had rusted shut being out of use.
Nice and neat job though.
3Back to top Go down   City Case Piano Hinge Empty Re: City Case Piano Hinge Fri Aug 01, 2014 8:13 pm
That is an excellent idea.
It costs a little extra but you can get them in solid brass or stainless steel which won't rust. The pin on a lot of them is steel which can rust.
1983 K100RS 0011171 Fricka 606 Alaska Blue 29,495 miles Damn K Pox Its a Bat outta Hell Now 37,190 miles.
