1Back to top Go down   Banjo Bolt Size? Empty Banjo Bolt Size? Sat Mar 07, 2015 12:24 am
Oliveri
Oliveri
I'm looking for a front brake master cylinder (13mm, no ABS) banjo bolt for my ’88 K100RT. I finally got a new master cylinder, but unfortunately have no hollow banjo bolt. The old one was mangled.
What is the correct size & where can i get one?
"Keep the paint up, and the rubber down
1988 K100RT...#0096960 ..."Heisenberg"...Status: Work in progress
http://www.oliveris.com.au
2Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 2:14 am
Any brake place should have one or two, 10mm Banjo bolt. Take the mangled one with you.
3Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 6:51 am
Oliveri
Oliveri
Thanks, any idea on the lengh of the bolt? The original is no longer available to me.
4Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 7:52 am
RicK G wrote: Take the mangled one with you.
Oliveri wrote:The original is no longer available to me.
The one on the other end of the hose is identical.
Banjo Bolt Size? Banjob10
5Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 4:25 pm
10 mm x 1 mm pitch
Be careful as banjo bolts also come with 1.5 mm pitch.
6Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 7:44 pm
Beat me to it Paul. IME most Japanese, Italian and German bikes come with 1mm pitch (Metric Fine). Kawasaki, for reasons best known to themselves, used Metric Standard (1.5mm). In these days of buying most things from one supplier's standard range I think even Kawasaki use Metric Fine now.
The other piece of advice I'd offer is forget MotoWhoever and buy stainless from ebay.
7Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 10:16 pm
Oliveri
Oliveri
Thanks everyone. Stainless, 1mm pitch, 10mm thread & 25mm long.
Perfect....
8Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sat Mar 07, 2015 10:23 pm
20mm you don't count the head on a hex head bolt only on a countersunk head.
9Back to top Go down   Banjo Bolt Size? Empty Re: Banjo Bolt Size? Sun Mar 08, 2015 4:59 am
Oliveri
Oliveri
....ops, yes of course. Thanks again.
