1Back to top Go down   brake pipe flare Empty brake pipe flare Tue Aug 11, 2015 2:57 pm
BooG
BooG
What are we saying regarding metal pipes running into calipers? Double flare or bubble flare? Copper pipe or cunifer? M10 x 1 mm thread on the unions?
2Back to top Go down   brake pipe flare Empty Re: brake pipe flare Tue Aug 11, 2015 9:43 pm
A Ball flare is the way and never ever use copper tube on brake lines iy has a nasty habit of getting holes at the most inconvenient times like when you are trying to stop.
3Back to top Go down   brake pipe flare Empty Re: brake pipe flare Wed Aug 12, 2015 12:52 am
Yes, M10 x 1.0 unions. And remember to support the pipe at each end so that vibration doesn't work harden the pipe causing it to stress crack.
4Back to top Go down   brake pipe flare Empty Re: brake pipe flare Wed Aug 12, 2015 6:35 am
Why not just use Aeroquip or Goodrich?
