1Back to top Go down   FD Shaft moving? Empty FD Shaft moving? Wed Aug 22, 2018 11:09 pm
Arrowkeen
Arrowkeen
Hi Gents
Have taken the clutch, plate and basket out to change clutch plate
While staring at it, i grabbed the FD? thing that the clutch basket bolts to
and was able to push it in and out of the motor about 5 to 6 miilametres, is this normal
to have play there? If there is, I might as well keep going in further in for repairs
as have gone this far
2Back to top Go down   FD Shaft moving? Empty Re: FD Shaft moving? Wed Aug 22, 2018 11:36 pm
That's OK when the clutch carrier bolts up all the slack should go away. There may be a slight movement.
3Back to top Go down   FD Shaft moving? Empty Re: FD Shaft moving? Thu Aug 23, 2018 12:59 pm
Arrowkeen wrote:Hi Gents
The clutch plate, disc and pressure plate (basket you mention?) are bolted to the output shaft, and as Rick says, will have some movement which goes away once the compression ring and hex nut are tightened down (and a new o-ring is used). Keep in mind that the end of the output shaft uses a shim of varying thickness. See this parts diagramme. It's number 19 in this illustration from ETK. Also, helps us if you include in your 'signature' just which model you're asking the question about.
FD Shaft moving? K100_o10
19Shim1,60MM108/198911211461742$12.52
19Shim1,75MM108/198911211461743$12.52
19Shim1.90MM108/198911211461744$12.52
19Shim2,05MM108/198911211461745$12.52
~Mac McCleary
4Back to top Go down   FD Shaft moving? Empty Re: FD Shaft moving? Sun Aug 26, 2018 8:34 pm
Arrowkeen
Arrowkeen
Cheers, Thanks guys
