1Back to top Go down   Speedo not working correctly Empty Speedo not working correctly Mon Sep 21, 2020 10:17 am
Middleton
Middleton
Sorry if this is a repeat but I would like some advice, my speedo won’t go past 40mph, my indicators work but do not auto turn off, I have removed the speedo sensor and placed a soldering iron close to the sensor with the ignition on but get no reading at all on the speedo, I have cleaned the connector at the end of the sensor under the side panel but still no luck, not sure what is the next step but any help welcome.
2Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 10:25 am
Here's some troubleshooting guidance that may help. Scroll down to the Fix a flaky speedometer link.
3Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 10:38 am
Middleton
Middleton
Thank you - that will be very useful
4Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 11:18 am
Auto turn off needs the speedo doing its thing, if its off then no auto turn off.
5Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 11:29 am
Middleton
Middleton
If my speedo is registering up to 40mph would that mean the sensor is working and it is something further upstream or could it still be the sensor,
6Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 11:38 am
It could also mean the sensor needs cleaning or the plug connector needs cleaning.....its near back of tank under right hand side panel, you can trace the cable up from the sensor.
7Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 11:53 am
Middleton
Middleton
Hi, thank you for your help, I removed the sensor and cleaned it, and followed the sensor wire up to the connector under the side panel and cleaned that but then got stuck on next step,
If the sensor was faulty could I still get a speedo reading up to 40 mph or if it is the sensor would I get nothing at the speedo. Is there any more hidden connections before I dive into the speedo itself.
8Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 12:38 pm
The plastic label on the speedo can wrinkle and lift up to where it stops the motion of the pointer.  This can be the result of long term parking outdoors in a sunny location.
9Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 1:40 pm
Middleton
Middleton
I will take a look at that tomorrow - Thank You
10Back to top Go down   Speedo not working correctly Empty Speedo Mon Sep 21, 2020 4:22 pm
daveyson
daveyson
If you unplug the wire from the flasher unit to the instrument cluster, the speedo might then work normally, but you would then lose the auto cancel feature. For some unknown reason I always turn it off manually, but only on a bike. Or cover the flasher units pin with a piece of paper to prevent the signal, or the instrument cluster pin. Maybe something wrong with that wire, or flasher unit. If you're reading 40mph maybe it takes twice as long as normal to auto cancel. The speedo sensor must be working (but maybe not correctly) or the speedo would read 0 kmh.
I had a problem like yours (but I never thought to take notice of the auto cancel feature) which was fixed by cleaning the contacts for the three pins inside the cluster and giving the pins a slight twist, for a tighter contact. You will see the ones I mean if you open the cluster. In my case the speedo would sometimes correctly read 60 mph,  and sometimes drop to 0 mph
 ~120,000 km
11Back to top Go down   Speedo not working correctly Empty Re: Speedo not working correctly Mon Sep 21, 2020 4:58 pm
Middleton
Middleton
Thank you, I will try that tomorrow, I am new to bike repairs so this is a new learning curve, is the flasher unit located under the tank ?
12Back to top Go down   Speedo not working correctly Empty Speedo Mon Sep 21, 2020 5:03 pm
daveyson
daveyson
Yep, it's green (usually) and rectangular, at the back of the relay box. You're looking for the blue/green wire,  pin 1.
 ~120,000 km
