1Back to top Go down   Transmission transplant checklist? Empty Transmission transplant checklist? Thu Jul 15, 2021 1:08 pm
KentM
KentM
I have a donor transmission being delivered in a couple days because my original trans has started slipping out of 2nd under load.
Before installing, I plan to open her up and checking that the grub screw is secure, locking it in place with locktite, if it hasn’t been already. While I’m in there, is there anything else of a similar nature I should be addressing?
'89 K100 RS Special
Code:
“Courage is not the absence of fear, but rather the assessment that something else is more important than fear.” ― FDR
KentM
KentM
Donor transmission arrived two days early. Encouraged to see the splines on the input look really healthy.
Transmission transplant checklist? D22fdf10
'89 K100 RS Special
Code:
Jamie64
Jamie64
Low milage donor ? the alloy looks fresh Smile
4Back to top Go down   Transmission transplant checklist? Empty Re: Transmission transplant checklist? Fri Jul 16, 2021 12:28 pm
KentM
KentM
Jamie64 wrote:Low milage donor ? the alloy looks fresh Smile
Low price donor… Pulled from an RT, which I am banking on being treated a little more kindly than my original RS tranny was.
Grub screw has been LockTite-d. Far from an expert, but the inside looked pretty clean to my eye.
'89 K100 RS Special
Code:
It's rare that anything really nasty happens inside a gearbox. Along with the older Moto Guzzis, they're about the simplest and most robust I've seen.
