1 Tuning My K100 Tue Feb 05 2019, 12:35
DBRMN
Now, I've been reading up on tuning TBs and have found a few posts that hold your hand through the process, linked below;
https://www.k100-forum.com/t1526-how-to-balance-the-throttle-bodies-solved
https://www.k100-forum.com/t3880-what-is-the-correct-procedure-for-synching-throttle-bodies-on-91-k100rs-4v
https://www.k100-forum.com/t5671-16valve-throttle-body-sync
https://www.k100-forum.com/t8259-tune-up-and-adjustments
However my question is, if I have modified the exhaust (pretty much straight piped) and half the air intake system, can describe in more detail if needed, then will adjusting the air-fuel mixture rectify this? As from when I tried to run the bike without an exhaust, the lack of back pressure prevented it from even idling, so is this even a problem I can fixed with tuning or is a much more thorough tune needed?
Simple question being how much tuning can you do on the TBs?
Thanks,
DBRMN
Thanks,
DBRMN
