1Back to top Go down   load shed Empty load shed Mon Aug 07, 2023 1:20 pm
jercr77
jercr77
as long as im asking, my small fire was actually enough to melt most of the wires in the harness. being that it is modded to nothing bmw left but drivetrain, i kept the fuel harness the ign harness, the were salvageable, the main harness is basically red, green, gfey and blue to the ign switch and runnin power to all from ign switch with no load shed, chassis ground to starter and fi relay. will it run without a load shed circuit.  evrything says keep it but thats not an option without buying a complete new harness with relays?
2Back to top Go down   load shed Empty Load shed Fri Aug 11, 2023 5:05 am
daveyson
daveyson
Removing the load shed relay should not prevent your brick from starting or running.
 ~120,000 km
