1 oil water pump rebuild Sat Feb 03, 2024 12:39 pm
Chipper
This follows on from @SunnyPerth post a few days ago. I am rebuilding my pump. Firstly, which way does the first rubber seal sit. I have assumed and inserted with the raised beveled crown section facing up to the impeller. I inserted the shaft and located the second seal with the blue ringed side facing down. Tapped down gently using the tool. Thinking now, that I have inserted the ceramic seal the wrong way as the very outer lip of the seal is not sitting down hard on the housing and proud 2mm. Depending on this and assuming I get it all the right way eventually, what is the torque for the new impeller style, bolt? cheers Angus.
