1 clutch problems Sun Sep 25, 2011 5:32 am
gabriel
Hi
I'vw been working on my bike for the past few weeks trying to remove the gearbox. I also decided to check the clutch. The components were stuck fast and I finally managed to remove the clutch.
unfortunately in my haste to remove the clutch I damaged the pins on the pressure ring (first cover under bolts)...doooh!
I have decided to replace the friction plate and the pressure ring but i have no idea how to balance the components. some claim it doesn't matter, but I know that BMW marked the plates for a reason...what happens when the pressure ring and pressure plate are replaced.
I also noticed a very light film of grease around the outer edge of the clutch components on the inside of the bellhousing. i cleaned the area and i had a look to try and figure where the oil or grease was originating.
i had a peek behind the clutch housing and it was dry.
i dont want to mess with the output shaft seal unless its absolutely necessary. i noticed a light film of grease covering the clutch input side of the gerbox. me thinks it's leaking from the gearbox.
anyway i have decided not to disturb the clutch housing and instead replace the clutch components. i also have the problem of the new components and how to balance them.
which type of grease do i use when installing the clutch components?
all suggestions are appreciated.
