1 [Solved] Non starting 92 K100LT Sat Mar 31, 2012 8:50 am
It started normally when I took it out of the garage for a run. Put gear on and went to restart and it didnt go. Battery was fine, fuel pump was clicking when ignition was on and fuel pump was running and returning fuel to tank when I pressed the starter button. No action from starter motor, not running or trying to engage or anything.
Subsequently I replaced the starter relay/solenoid. While I had this out and was waiting for the new one to arrive I also stripped and cleaned the starter motor but to be honest it looked fine inside.
I put the starter motor back reconnected to the old relay and it started once and problem was same. Couldnt get it to go again.
This morning I put in the new relay, checked everything and it ran fine. It stopped and restarted maybe a dozen times and was fine to the point that I was now sure it was solved. Then on the last one it cut out and wouldnt start again. Nothing from starter motor. This is with the new relay in so I know its not the relay and dont think its the starter motor now. I did think if it was a problem in the fuel injection system that I would get the engine turning over and not starting rather than not turning over at all.
Any advice?
Last edited by 92KK K100LT 193214 on Tue Jul 10, 2012 4:41 pm; edited 2 times in total (Reason for editing : Solved.)
1971 Yamaha 125 YAS-1
