1Back to top Go down   abs removal Empty abs removal Fri Jun 29, 2012 5:34 am
ridefar
ridefar
I am new to your forum and to the K bike. I have always looked at the K as the "dark side" in BMW world. I recently came to own a 1989 K100rs in need of some repairs and tlc. I will be kind in saying this bike was not stored well. Long story short I decided to do away with the ABS brakes. That has all worked well and I rode the bike today for the first time. The ABS dash light stays on. Anyone know a good way to eliminate it?
2Back to top Go down   abs removal Empty Re: abs removal Fri Jun 29, 2012 5:39 am
Permanently on or flashing. If flashing it is ABS fault but permanently on it is a bulb fault from the bulb monitoring unit.
The ABS is fairly long lived but prone to stupid things being done. No don't ask. Embarassed
3Back to top Go down   abs removal Empty Re: abs removal Fri Jun 29, 2012 5:44 am
ridefar
ridefar
steady on.
4Back to top Go down   abs removal Empty Re: abs removal Fri Jun 29, 2012 5:51 am
There is a bulb monitoring unit which tels you if the park, tail or stop light stop working and if one of those bulbs are out it will light the red light with the triangle. If there is an ABS fault the red light will flash when the ignition is on and kill switch is on. This is usually easy to fix.
5Back to top Go down   abs removal Empty Re: abs removal Fri Jun 29, 2012 6:36 am
Rick G wrote:There is a bulb monitoring unit which tels you if the park, tail or stop light stop working and if one of those bulbs are out it will light the red light with the triangle.
Often caused due to a malfunctioning brake light switch.
6Back to top Go down   abs removal Empty Re: abs removal Fri Jun 29, 2012 9:12 am
ridefar
ridefar
The red triangle lights when the ignition is turned on, along with abs light, when the brakes are applied the red triangle goes off. The abs stays on. The running lights and brake light are working properly.
7Back to top Go down   abs removal Empty Re: abs removal Sat Jun 30, 2012 9:00 pm
ridefar wrote:steady on.
If you`re a lucky guy, it`s just your switch.
Check close to the bottom in this thread.
8Back to top Go down   abs removal Empty Re: abs removal Sat Jun 30, 2012 10:06 pm
ridefar
ridefar
hey Inge, you do understand that I have removed all abs components. I have the bike set up with conventional brake system. I thought maybe someone knew an easy way to turn off abs dash light. Thanks.
9Back to top Go down   abs removal Empty Re: abs removal Sat Jun 30, 2012 10:35 pm
was inge saying to remove the relay ....which controls the light ?
10Back to top Go down   abs removal Empty Re: abs removal Sat Jun 30, 2012 10:53 pm
ridefar
ridefar
I removed the blue relay. Isn't that the right one?
11Back to top Go down   abs removal Empty Re: abs removal Sat Jun 30, 2012 11:31 pm
In the electricals box under the tank there 4 small relays in the front right corner the ABS relay is the left rear of those 4 relays. From factory it was blue but it could have been replaced by a black one.
This should get rid of the light.
I understood that you were considering removing the ABS but had not as yet removed it.
12Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 3:26 am
MT350Explorer
MT350Explorer
If it's still on how about removing the bulb?
1991 K100 RS 16 valve
13Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 7:47 am
Rick G wrote:the ABS relay is the left rear of those 4 relays.
+1.
Rick G wrote:I understood that you were considering removing the ABS but had not as yet removed it.
Thanks Ricky, then I wasn`t the only one.......missing the reading glasses.
14Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 8:47 am
ridefar
ridefar
Yes that is the relay I removed. I am surprised that the caution light comes on when engine is started then when brakes are applied (front and rear) goes off and stays off. The abs light stays on.
15Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 9:36 am
ridefar wrote: I am surprised that the caution light comes on when engine is started then when brakes are applied (front and rear) goes off and stays off.
This is normal, ABS equipped bike or not.
ridefar wrote: The abs light stays on.
This is a bit more unormal, if you have removed the correct relay.
The only function this relay got is to power the ABS warning lamp.
abs removal Abs_b10
16Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 10:38 am
I would be inclined to remove the bulb from the instrument panel. The panel can be a bit awkward to get of but it comes apart very easily.
17Back to top Go down   abs removal Empty Re: abs removal Sun Jul 01, 2012 7:07 pm
ridefar
ridefar
took the relay out. had a slightly different configuration than your pic. every thing is working well. thanks for all your help.
