1Back to top Go down   ENGINE COVER BOLT RUBBER SEALS. Empty ENGINE COVER BOLT RUBBER SEALS. Tue Aug 18, 2009 7:24 am
gabriel
Hi everyone
I received my spare parts order from Motobins which included the rubber seals which attach to the engine cover bolts.
The engine cover bolts have a raised section halfway along the bolt, and the rubber seal is not large enough for the bolt to pass thru.
any advice? i was thinking perhaps soak the rubber seals in boiling water, which might give them more flexibility.
regards
gabriel
2Back to top Go down   ENGINE COVER BOLT RUBBER SEALS. Empty Re: ENGINE COVER BOLT RUBBER SEALS. Tue Aug 18, 2009 1:02 pm
Gezar
i just put a dab of oil on mine when I pooked them through.
3Back to top Go down   ENGINE COVER BOLT RUBBER SEALS. Empty Re: ENGINE COVER BOLT RUBBER SEALS. Sat Aug 22, 2009 6:25 am
Kerswellcrank
Kerswellcrank
Not positive, but I think boiling rubber parts might make them harder rather than softer.
A small smear of silicone grease works well on rubber, available from plumbers merchants, (used for assembling parts with rubber seals).
Otherwise, petroleum jelly (Vaseline) works quite well.
Cheers,
Steve.
