1Back to top Go down   Help needed Empty Help needed Mon Aug 31, 2009 10:00 pm
I am finishing to complete my document on troubleshooting the EFI/Electronic ignition.
The last chapter I am working on is about the ignition coils.
Knowing that an ignition coil is essentially an autotransformer with a high ratio of secondary to primary windings and the primary and secondary windings are not actually separated I did some test.
On a set of K75 coils, I can find a resistance between the primary and secondary.
When testing my spare K100 coil, I get nothing.... Nada!
I never tried this coil on the bike and it could be a bad one.
If you have a spare coil, could you please take your Ohmmeter and report what resistance you find between the primary input and the coil output (spark plug wire)? The K100 has 2 output on the coil but both of them should show the same resistance in relation to the input.
If we find the value of the resistance, this could be a big help when trying to troubleshoot an ignition problem.
Help needed Coil_q11
Bert
Help needed Frog15Help needed Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   Help needed Empty Re: Help needed Tue Sep 01, 2009 2:52 pm
scottiesharpe
scottiesharpe
I have some spares. I'll see what I can do.
3Back to top Go down   Help needed Empty Re: Help needed Wed Sep 02, 2009 1:44 am
Just a quick thought the K75 have open circuit spark plug leads with a spark gap in them just checking you are not checking via the lead?
4Back to top Go down   Help needed Empty Re: Help needed Wed Sep 02, 2009 1:48 am
gabriel
i've updated my post "1984 K100 WON'T START" and I mentioned about my Igbition Coils. I also received no reading when i tested the secondary windings. the haynes manual states that there is no resistance values to check for the K100.
perhaps it's because this ignition coil is responsible for two cylindres instead of one?
anyway, i've tested my ignition coils and there was no reading. I think this is normal.
