1 Instruments Mon May 13, 2013 11:54 am
I have the instrument cluster apart as some bulbs don't work and the LCD shows hieroglyphics instead of a gear number.
The last guy in here decided black silicon was the way to fix a broken O'Ring so it was difficult to split and the bulbs that were not working have had the flexible PCB folded back 180 degrees so the contacts for these bulbs were folded back under the PCB instead of being down the holes beside the bulbs, which is where I think they should be. But no sign of water ingress
All too easy to fix but how about this LCD, is it toast? I was pretty sure it was toast looking from the outside and tried contacting Kbikes in the USA for an LED kit and a working LCD which he has on his site, but communications there sort of faded away.
Anyway, can I recover this in anyway?
