1Back to top Go down   New forum member in Arizona! Empty New forum member in Arizona! Fri Sep 19, 2014 8:14 pm
John in Phoenix
John in Phoenix
Folks-
A 1984 K100RS followed me home the other day...
Her problems:
Dead battery.
Brakes have failed.
Radial crack in the rear brake rotor.
Worn out front rotors.
Broken rear brake reservoir.
The one key doesn't unlock the fuel cap.
Fun and games!  Any ideas will be appreciated!
Thank you!
2Back to top Go down   New forum member in Arizona! Empty Re: New forum member in Arizona! Fri Sep 19, 2014 8:42 pm
Hi John and welcome to the forum.
Here are my comments about your problems:
- Dead battery: this is like tires or brake pads.... Consumable
- Broken rear brake reservoir: Known problem due to UVs. Replace the reservoir (It's cheap)
- Radial crack in the rear brake rotor: The original rear rotor was replaced under warranty due to a cracking         problem. If yours is the same as the front brakes (not plain rotor but has holes in it), this is certainly an original with the known problem
- Worn out front rotors: Mine are at the minimum thickness but they are still good. When they reach the minimum  thickness they are still OK but you are just taking a chance that they could warp if they overheat.
- The one key doesn't unlock the fuel cap: Many K100 keys will work on other bikes. Try to find somebody with a K75 or K100 and try his keys.
These problems are easily fixable without costing you an arm and a leg....
CF
New forum member in Arizona! Frog15New forum member in Arizona! Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   New forum member in Arizona! Empty Re: New forum member in Arizona! Sat Sep 20, 2014 2:08 am
JR_K100RS
JR_K100RS
G'day again John , X2 on CF's comments , I'm on my 3rd rear brake reservoir , not a biggy just replace it , as far as the brake rotors go , I replaced my rear one with a complete ( carrier plus disc ) EBC unit , very nice , the fronts I went a slightly different route , removed the discs from the carriers by very carefully grinding & drilling out the rivets , be super careful here as the carriers can be easily bent if you are heavy handed , once removed I replaced the disc with "Braking" brand discs ( Italian ) they bolt up as semi floaters , they look & work very well
JR
Last edited by JR_K100RS on Sat Sep 20, 2014 3:33 am; edited 1 time in total (Reason for editing : spelling)
4Back to top Go down   New forum member in Arizona! Empty Re: New forum member in Arizona! Sat Sep 20, 2014 2:44 am
JR_K100RS
JR_K100RS
This is what I'm using up front ,"Braking" BW02FI , see www.braking.com
www.braking.com/catalogue/intro.php?caricaRicerca=938177
JR
5Back to top Go down   New forum member in Arizona! Empty Re: New forum member in Arizona! Sat Sep 20, 2014 2:28 pm
brickrider
brickrider
Welcome John.  The support you need will be found here, I have no doubt. This is a wonderful resource for the Flying Brick owner. Very Happy
