1Back to top Go down   K75 running very rich Empty K75 running very rich Thu Oct 08, 2015 7:26 am
Grahame
Grahame
Hi I'm a new member with a problem K75RT.
The bike was running well until it stalled at a junction and wouldn't start again.
Can get the engine to run reluctantly but only with the throttle half open, lots of smoke. The engine stops if the revs drop below 3000, the bike is unridable.
The plugs are all identically black and sooty (not oily)
The indications are the engine is running very rich.
The injection control and ignition units are ok. The injectors are all ok. Examined the air flow meter and it is mechanically ok but haven't tested the air temperature sensor or potentiometer.
The fuel pump is running and there are no internal leaks within the tank pipework.
Suspect either the pressure relief valve on the fuel pump or the fuel pressure regulator (although, looking at a diagram of this unit it looks like it can only fail open which would give low pressure at the injectors) Anybody had a similar fault, I've looked back on the forum but can't match the symptoms exactly. Any advise welcome.
K75RT ABS Mystic Red 1995 7th owner
Engine No.753EA 0294
Chassis No. 03706294134
Mileage 24/12/18  40,399
2Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 7:43 am
mike d
If the water temperature sensor has failed, it can easily be telling the EC that the bike is extremely cold (all the time) so the mixture will be very rich.
Using a pressure gauge you can measure both the pump and regulator pressure.
If you are a member of the UK BMW club, they have a tool hire facility which includes the correct tools for measuring the pressure, plus many other special tools if required.
Mike
3Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 7:53 am
Grahame
Grahame
Thanks Mike,
I was thinking of joining the BMW owners club, I bought the bike of the northern area social secretary.
Grahame
4Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 9:52 am
mike d
Hi Grahame,
If you join the club now you will get the rest of this year and all of 2016 for the normal £30 joining fee. (was £27.00 but just gone up).
I am the tool hire secretary, so feel free to contact me for any tools etc.
Have a look at the downloads page of this very forum for some of the best diagnostic methods for the 2 valve models. Step by step instructions, and very good interactive diagrams.
Mike
5Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 9:54 am
mike d wrote:If the water temperature sensor has failed, it can easily be telling the EC that the bike is extremely cold (all the time) so the mixture will be very rich.
+1  This is the likely problem but it may just be the sensor is not earthing due to corrosion. Try rigging a temporary earth to the sensor body and see if that makes a difference to the running.
Or, test for earthing with a DMM (engine off)
 K75 running very rich Austra12    Fuel:  95 Octane
6Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:01 am
Grahame
Grahame
Thanks, will check it out, but I think the bike would start as normal from cold and the problem only appear as it reached working temperature if it was the sensor.
The bike will barely start when cold and is difficult to keep running, the engine dies below 3000 revs, clouds of smoke.
Grahame
7Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:09 am
Grahame
Grahame
mike d wrote:Hi Grahame,
Mike
Thanks Mike, I have learned all I know about fault finding from the technical support help on this site (not sure if that's a vote of confidence!)
Grahame
8Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:15 am
mike d
It's probably the best K series resource available K75 running very rich 112350
Mike
9Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:19 am
Grahame wrote:Thanks, will check it out, but I think the bike would start as normal from cold and the problem only appear as it reached working temperature if it was the sensor.
Grahame
Not so. At 20°c the FICU should be reading about 2.5kΩ. If its not earthing then the FICU will see infinite resistance. I think charlie worked it out last week that the estimated temperature would be minus 200° or more
You can simply test by taking the FICU plug off and measuring the resistance from pin#10 to earth. Should be close to 2.5kΩ
10Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:28 am
Grahame
Grahame
Grahame
Ok thanks,
I'll check it out.
11Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 10:41 am
Grahame, probably a good idea to have a good read of this...
troubleshooting starting
Instructions on testing sensor outputs at the FICU plug about ¾ way down.
This is the logical explanation and its easy to test. If not this then check fuel pressure.
12Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 11:17 am
Grahame
Grahame
Kaptain Holister wrote:Grahame, probably a good idea to have a good read of this...
Many thanks, Its a brilliant resource clear and easy to understand.
Grahame
13Back to top Go down   K75 running very rich Empty Re: K75 running very rich Thu Oct 08, 2015 6:28 pm
Grahame,
I've had a fuel pressure regulator fail where the internal valve came out of it's socket, blocking the output and causing excessive pressure at the injectors.
 K75 running very rich Sam_0910
Paul
