1Back to top Go down   Adjustable handlebar risers Empty Adjustable handlebar risers Sun Aug 02, 2015 4:14 am
nino
Hi, I found adjustable risers on Aliexpress for only 51 dolar, free delivery to Croatia and ordered it. Did anyone od our forum tried it? I think it lifts nadlebars for cca 5 cm but you can push it forward, or backward as you like.
When I get and try I ll send a report.
Best regards
http://www.aliexpress.com/item/Universal-Black-Anodized-2-Inch-Pivoting-Motorcycle-Handlebar-Riser-For-7-8-Bars-Clamp-ZJMOTO/32319799322.html
2Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Sun Aug 02, 2015 5:46 am
Comberjohn
Comberjohn
I've used 25mm risers and found them about right. 50mm is a lot, but depends what you are after.
I typed 'k100 handlebar riser' into eBay and it brought out several similar to mine in 25 and 30mm sizes. They're very difficult to spot on the bike.
No forward or backward motion though. You would need to make sure your type are well tightened for braking.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
3Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Sun Aug 02, 2015 6:14 am
nino
I try to find solution to sit more backward. With this adjustable handlebar could be a problem with cables even RT variant. I ll see, 50 USD wasnt much even it failed
4Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Sun Aug 02, 2015 6:15 am
I agree with Comberjohn. I have 25mm risers on my bike and they are just about right with the standard K100 bars.
5Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Mon Aug 03, 2015 8:31 pm
The risers you have found are a knock off of the original Rox Risers, but at a cheaper price. Here's a link:
Rox Risers
They work well for dualsport/GS-type bikes as you can swing them a bit when riding off road when needing to stand up. Be careful with hydraulic hose and control cables. Often these need to be lengthened when at the extreme positions.
History is a vast early warning system ~Norman Cousins - Political Journo, Editor, Author & World Peace Advocate, 1915 - 1990 - Wikipedia
1977 R75/7-100, '93 K11/K12 Big Block, '93 K1100RS, '95 R100 Mystic, '96 K1100RS, 2 x '98 K1200RS, '06 K1200R & '09 K1300GT. Projects: 1993 & '96 K1100RS, & the 2nd '98 K1200RS
6Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Tue Aug 04, 2015 12:27 am
shintaro
shintaro
Hi wondering about the 25mm risers, are they a straight install? By that i mean are all original cables and hoses still used, or are there any other mods needed.
thanks.
7Back to top Go down   Adjustable handlebar risers Empty Re: Adjustable handlebar risers Tue Aug 04, 2015 12:55 am
'Bar risers of 25mm height (for 22mm saddles) for K bikes don't have a provision for fitting the handlebar dashpad so you have to drill and tap or rivet a holder into the rearward facing part of each one if you intend on retaining the pad, easily done.
Adjustable handlebar risers Risers10
Otherwise they're a straight bolt on. All cables and brake hose are stock length items on mine.
8Back to top Go down   Adjustable handlebar risers Empty risers Tue Aug 04, 2015 10:02 am
Ajays
Ajays
Unbolt the original top clamp and reassemble it upside down then add a flat clamp. Job done. I did this on my K's and it worked fine.
10 minute job.
Try it for yourself. I added two black ties to keep the cover in place.
         Ajays
Adjustable handlebar risers Th_Kengine_gif
AJAYS
