1Back to top Go down   ABS K75 final drive Empty ABS K75 final drive Fri Jun 25, 2021 7:36 pm
arbalest
I want to use an ABS K75 final drive (37/11) (available on Fleabay) in a non abs application. 76 airhead R90/6 with modified K100 s.a., K1100 18" three spoke rear wheel sidecar rig. Will the ABS ring cause any problems or can I just remove it?
2Back to top Go down   ABS K75 final drive Empty Re: ABS K75 final drive Fri Jun 25, 2021 7:44 pm
I presume you are talking about the ABS ring on the rear wheel?  If so just remove it.  From memory there are three screws.
3Back to top Go down   ABS K75 final drive Empty ABS ring Sat Jun 26, 2021 9:01 am
arbalest
Thanks.
