2
Re: What is this?! Sun Aug 29, 2021 7:18 am
moriarti
DEFINITELY. The splines look well worn, i would remove drive shaft and clean /check splines.
1984 k100 rs red/black VIN 0004449 Now sold to Olaf
3
Re: What is this?! Sun Aug 29, 2021 12:10 pm
Don't worry, there's more where they came from.Clintinz wrote:It looked like rust or old dried grease but after drowning it in degreaser I came across metal filings. Should I be concerned?
That is an excellent photo. Take another with the camera angled so the end profile of some of the splines' ends can be clearly viewed. If their points are chiseled on one side like a saw tooth when viewed from their ends, mileage on them will be limited but I can't tell how much wear they have.
These are worn but not worn out.
5
Re: What is this?! Sun Aug 29, 2021 9:34 pm
Re: What is this?! Sun Aug 29, 2021 10:14 pm
Clintinz
Phew! I’ll grease them up and put it back together. Thanks guys
7
Re: What is this?! Mon Aug 30, 2021 6:43 am
Just stick to a yearly regrease with Castrol Optimol / Straubags / whatever and they should go on for quite a while yet.
Re: What is this?! Mon Aug 30, 2021 10:34 pm
Yeah, that drive shaft has maybe 100 miles left in it if you are real gentle on the throttle.
A brand new one is $383 at MaxBMW. If you're not in a hurry, you should be able to find a good one on eBay for $200 or less.
Re: What is this?! Tue Aug 31, 2021 9:51 pm
gabriel
Hi
Unfortunately your splines are starting to wear out.
How long it lasts you depends on how you ride your bike.
Thrash your bike and they won’t last much longer. If you are gentle with the throttle, you might get many more miles.
It’s up to you.
Make certain your clutch arm, located at the back of your gearbox is greased up.
If not, your clutch cable will snap and replacing it won’t fix the problem unless you also grease the clutch pivot arm.
Good luck.
It’s up to you.
Good luck.
1992 BMW K75s
11
Re: What is this?! Tue Aug 31, 2021 10:48 pm
Re: What is this?! Thu Sep 02, 2021 2:31 am
Clintinz
Given that buying over seas in NZ $ then paying shipping it going to come close to $1k and i can’t find one locally. I’m thinking of replacing the whole back end from the gear housing, swing arm, drive shaft stand etc from a k1100rt. This would be similar price (Which I can find locally) and I can fit a larger rear wheel. Question is… can my existing alternator, starter motor and rear diff fit on the k1100rt back end?Point-Seven-five wrote:Yeah, that drive shaft has maybe 100 miles left in it if you are real gentle on the throttle.
13
Re: What is this?! Thu Sep 02, 2021 8:00 am
Starter motor and alternator, yes. Rear diff, no. You'll have to get the complete rear end, from the bell housing back.
