fork travel Sun Nov 28, 2021 12:19 pm
arbalest
![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
Spec's say front wheel travel is 185mm. Is that the unladen travel from droop to full compression? I am considering modified fork legs in a version of a leading link fork for my sidecar rig. I'm shooting for about four inches of travel. I would like to shorten the fork tube considerably, using a cut down stock fork spring. Cutting down the fork spring has two advantages. First the spring rate increases with decreasing length. The question is, how much can I shorten the spring to get my four-ish inches of compression with the correct amount of rebound?
