fuel pump problem Sun May 08, 2022 10:51 pm
cfmckay
I have utilized crazy frogs very detailed information on this forum to trouble shoot a fuel pump problem. These are the things that I know after approx. 40 hours of trouble shooting. The pump is good, hard wired it runs fine. I have 12 volts at the green/white wire to the pump when I press the starter button, remove pump check voltage at pump 12 when start button is pressed. I have confirmed good ground and all parameters according to crazy frogs guide for the fuel pump trouble shooting. Again, 12v from fuse block to the starter relay all the way to the pump. I have replaced the tank connector with the 4 pin connector removed from the relay box. It would seem that any time the starter is in the circuit the fuel pump does not work even though the meter tells me the pump is receiving 12 volts. My suspicion is that the starter is some how disrupting the ground connection for the pump. Anyone have any thoughts on this??? I would greatly appreciate some input. Thanks, Craig
