1Back to top Go down   Brake Disc cap nuts Empty Brake Disc cap nuts Wed Aug 10, 2022 4:02 pm
gravelsandwich
gravelsandwich
Has anybody tried using connector cap nuts for attaching brake discs to the center hub? They would look a bit neater than a M6 bolt and lock nut. An M6x12mm connector and an M5x10mm bolt.
https://www.ebay.com.au/itm/144111618057?var=443542560315
2Back to top Go down   Brake Disc cap nuts Empty Re: Brake Disc cap nuts Fri Aug 12, 2022 9:44 am
bad boy
bad boy
Two Wheels Better wrote:
Big Bock K100
post #38
Wed Jan 21, 2015
I've found the perfect brake disc hold down screw from BMW.
It's a T30 Torx®, part number 34 11 7 700 989, with shoulder, 8 x 27mm x 1.25 thread pitch, from any late model R, K or S Beemer.
Brake Disc cap nuts Imag1026
No machining's required and they clear the inside of the fork legs by a country mile.
Cheerz, David
Brake Disc cap nuts 9438-010
