![duck](https://2img.net/u/4211/29/48/93/avatars/3060-34.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
Number of posts : 4392
daveyson wrote:If the hazard lights work normally, I will also guess that the problem is a poor earth to the flasher unit, because the hazards get earth from the hazard switch. Pin 31 is earth. It's best to find the fault before fixing it, but sometimes I just get lazy and try a quick fix, like say giving the unit and it's holder a clean and a spray of electrical contact cleaner, that might fix it. While you're there, might as well give the others a clean too.
Power is from fuse 7 for the indicators, and fuse 3 for the hazards.
Pin 31 is the main ground for the flasher relay. The ground from the hazard switch has minimal current to ground via the W pin as it is just the trigger for hazard mode of the flasher relay.
![bulb monitoring relay box indicators 5taKRQA](https://i.imgur.com/5taKRQA.jpg)
