Desperate.... K100RT 1985 - starting Wed Feb 07, 2024 1:53 am
Kendallsr
![Kendallsr](https://2img.net/u/4211/29/48/93/avatars/8433-28.jpg)
It's been a journey and it's only been ten days since I bought the bike as a non runner and had been sitting for 15 years.....
New Oils all round.
New plugs
new petrol pump
Injectors removed and professionally cleaned and they all squirt well
Fuel moves in the tank and comes in & out via the respective fuel lines
Fuel filter new and facing the correct way.
Have 7 litres on fuel
Check earth under seat and the one by battery - both cleaned
Spark plugs spark and connected in the correct order....
All lights works and brake light switches
Ignition on, all lights are on
Starter button pressed - fuel pump kicks in and the engine starts
with 2 to 5 second ds the engine stops
It doesn't like any throttle
removed the Throttle connection to the right of the injectors no change
Borrowed an ECU and tried this - no change.
Frustration and lots of swearing and still no further forward.
I'm not a mechanic just an bike enthusiast but in desperate need of some please...
Thanks, Stephen
New Oils all round.
New plugs
new petrol pump
Thanks, Stephen
