1Back to top Go down   Fuel Pick Up problem Empty Fuel Pick Up problem Sun Oct 02, 2011 9:32 am
Sidecarjohn
I realise the problem of fuel pick on the K is fairly well known, but is there a realistic solution ?
When the tank still has over a gallon (5 litres) remaining, misfires occur usually when cornering fairly hard. OK we run an outfit, which will mean there's the effect of the bike not leaning, but the problem is a known issue regardless.
Any suggestions as to a viable solution, so that I can actually benefit from having a 20 litre fuel tank ?
Question
http://www.sidecarjohn.co.uk
2Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Sun Oct 02, 2011 10:11 am
beanoldboy
beanoldboy
baffling.?? . . . . not confounding , i mean a inert material formed into a hoheycomb like configuration inserted with the hex tubes vertical to prevent the fuel sloshin ?
88 k100 rt
86 k100 rt
84 k100 rt
http://www.airware.com.au
3Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Sun Oct 02, 2011 10:15 am
Old farts like us shouldn't be going round corners fast John Ha Ha Ha!
Put a small pick up tank, with the pump in it, down lower on the chair and let the main tank drain into it. Kills two birds with a few extra litres.
4Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Sun Oct 02, 2011 10:31 am
Sidecarjohn
I'm basically looking for a solution that involves the existing hardware. Fitting extra tanks isn't currently part of the thinking. However, won't dismiss the idea of a pick up tank. How big and located where might help the decision ??
5Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Sun Oct 02, 2011 10:42 am
ReneZ
ReneZ
Try to put a piece of fuel hose on the return that feeds back into the pump recess and check that your pump (not just the 'clamp') is seated as deep as possible.
Rene
BMW K100 - 1985 (0030029) Scotland Fuel Pick Up problem Rain
6Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Mon Oct 03, 2011 11:53 am
Comberjohn
Comberjohn
To expand a bit on ReneZ thought about the pump's position.
Make sure the pump is turned so that the fuel pick-up port on the base of the pump is as low in the tank as possible.
I found that, if you are pushing your luck on reserve, it can make a difference of an extra 10-15 miles. May help this problem.
7Back to top Go down   Fuel Pick Up problem Empty Re: Fuel Pick Up problem Mon Oct 03, 2011 6:21 pm
ReneZ
ReneZ
There is something in the BMW info as to where the + and - of the pump contacts should be fitted in the white clamp that holds it in the tank, I think this is exactly for that reason
Rene
