1Back to top Go down   REAR SUSPENSION QUESTION Empty REAR SUSPENSION QUESTION Tue Mar 27, 2012 7:23 am
CanberraDave
CanberraDave
Well folks, I have just finished installing the second hand 16 tooth shaft and final drive. All greased and ready to go. It has been a while since I took it apart and had a question about re-fitting the rear shocky. Where it mounts to the final drive there is a nut and a washer. Does the washer go on the inside against the final drive, then shocky and finally nut or is there nothing on the inside and washer and nut on the outside?
I have the nut and washer on the outside as that is how it looks in the workshop manual I have.😕
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
2Back to top Go down   REAR SUSPENSION QUESTION Empty Re: REAR SUSPENSION QUESTION Tue Mar 27, 2012 8:31 am
Nut, then washer, then shockie, then FD.
3Back to top Go down   REAR SUSPENSION QUESTION Empty Re: REAR SUSPENSION QUESTION Tue Mar 27, 2012 8:32 am
You got it right Dave if it is a OEM shockie but a Koni or Ikon has a washer on both sides.
4Back to top Go down   REAR SUSPENSION QUESTION Empty Re: REAR SUSPENSION QUESTION Tue Mar 27, 2012 5:46 pm
Dave,
It's worth tightening the top fixing first and seeing how the shock sits on the FD. My Spax needed a washer on the inside....just a thought.
5Back to top Go down   REAR SUSPENSION QUESTION Empty Re: REAR SUSPENSION QUESTION Wed Mar 28, 2012 6:13 am
CanberraDave
CanberraDave
Thanks for that guys. Paul I did tighten the top first, but purely by accident.cheers
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
