1Back to top Go down   WHAT THE HECK HAPPENED????? Empty WHAT THE HECK HAPPENED????? Thu Mar 08, 2012 5:40 pm
Puccini
Gentlemen,
I'm really puzzled and troubled.
About 2 months ago my 85 K100RT (21,000 mi.)
Totally shut down as I was rolling to a stop on a highway.
No lights, No engine, No NOTHING.
I tried to jiggle the stop switch and the ignition switch and a few other things.
No help.
In about 2 minutes it popped back on and ran perfectly for another month till I garaged it
for a winter layup.
I put a battery minder on it to keep the battery topped up.
This morning I took it out as the weather was very warm.
Put on the "choke" hit the start switch and it started running as usual for warmup mode.
Then, all of a sudden, same thing. DEAD.
After 2 minutes it popped back on. Same way as before.
I understand the ignition swich was replaced about a year or two ago.
With much trepidation I went for a ride at low and high speed for an hour or so, 35 miles + and it ran perfectly.
Whats going on here.
I'm starting to distrust this bike.
Gerry
Near Philadelphia, PA (USA)
2Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Thu Mar 08, 2012 6:05 pm
what have you done about prevention of corrosion ..or should that be cleaning up all electrical connections ?
the fuse holders (clips) the relay sockets etc all need to be checked if you are having issues like that .
kinda sounds like the ignition switch to me anyhow ....but also check the starter motor brushes ......they provide the ground signal for the load shed relay and are a known issue for acumulating dust and are on the list for checking ..
we have seen similar issues of cutting out when a short was found on the brake light power cable ...after the brake switches ...turns out it was a crushed cable under a washer for the rear suspension unit along the frame .
hope that helps
3Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Thu Mar 08, 2012 6:19 pm
Ghost who rides
Ghost who rides
I had similar issues last year and a strip of the ignition switch, fiddly but fairly simple , fixed it . Mine wasn't dirty but a spring had got out of position . Followed the advice in a thread here and stretched the springs slightly , better of course would be to fit new springs.
In retrospect the switch felt rough , now smooth as .
Hope your issue is that simple .
4Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Thu Mar 08, 2012 7:00 pm
beanoldboy
beanoldboy
Similar experience here, ended up being a break in a cable under the tank that would open and close circuit with bumps in the road or a turn of the bars.
Best of luck mate, dont be discouraged , these bikes sometimes just want our attention .
http://www.airware.com.au
5Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Thu Mar 08, 2012 7:05 pm
japuentes
japuentes
Hi there, I'll go with Charlie regarding the starter, I´ve been there.
Best regards
JAP,
6Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 4:32 am
captaink
captaink
Hi there, sounds similar to an issue i had, this is what i found affraid
http://k100rt.aforumfree.com/t2391-ignition-switch
7Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 4:36 am
yep a good find captaink ,,,,cheers for the reminder !
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWHAT THE HECK HAPPENED????? Au-log10
8Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 5:20 am
One thing that may play into the mix is the often found habit of having many keys on one ring and when your ignition key is in the ignition the rest of then weigh on that ignition key and pull it off centre which can lighten the load on one side of the barrel and allow corrosion to do its best in there. Do you have such a key ring? Perhaps this may help point you in the right direction. keith
9Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 5:28 am
@charlie99 wrote:yep a good find captaink ,,,,cheers for the reminder !
+1. WHAT THE HECK HAPPENED????? 212902
Here is a link to a "how to" dismantle the older type of ignition switch.
10Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 7:09 am
Puccini
OH HELL,
My German is a little rusty. You see, when I was younger I had a Ducati so I had to study Italian. I guess I'll have to enroll in some new language classes
11Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 7:20 am
If the starter brushes are had it the engine will still run just the headlight and horn, blinkers etc dont work.
I would go with the ign switch for a first port of call.
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
12Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 8:41 am
Ghost who rides
Ghost who rides
Captink's link is the one i used too to fix my problemo .
This forum is the "duck's guts " for keeping these old nails on the road , may not be your answer Puccini but these guys will get VERY close !
How reassuring is that? Very very reasuring IMHO
13Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 8:54 am
Just to add a bit more
I had a fuel pump do a similar thing a few years ago and again last year so It may pay to keep that in mind as well.
14Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 9:55 am
japuentes
japuentes
@Rick G wrote:If the starter brushes are had it the engine will still run just the headlight and horn, blinkers etc dont work.
Wen I had the starter failure, the engine would not start. Had to put the bike on gear and sligthly move it back and forward to then start the engine.
Best regards
JAP
15Back to top Go down   WHAT THE HECK HAPPENED????? Empty Re: WHAT THE HECK HAPPENED????? Fri Mar 09, 2012 7:41 pm
Best regards
JAP
That is quite right but the starter brushes being bad won't stop the engine from running so it also won't make it stop. It is the starter motor that prevents it from starting not a lack of power to the ignition system.
