1Back to top Go down   Gear lever: am I screwed? Empty Gear lever: am I screwed? Mon Jul 23, 2012 3:33 pm
ali2908
ali2908
I was just giving the bike a check before booking its first MOT in 12 years and could not select any gears, found the gear lever splines damaged, see the pics below. If I get another lever do you think I would get away without replacing the shaft as well?
Gear lever: am I screwed? 20120711
Gear lever: am I screwed? 20120712
Gear lever: am I screwed? 20120713
Your valued opinions always welcome
Ali
1985 K100 RS
Last edited by Guest in the House on Thu Jul 26, 2012 1:06 am; edited 3 times in total (Reason for editing : signature edit)
2Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 4:43 pm
nino
ali2908 wrote:I was just giving the bike a check before booking it's first MOT in 12 years and could not select any gears, found the gear lever splines damaged see the pics below. If I get another lever do you think I would get away without replacing the shaft as well?
Ali
1985 K100 RS
No teeth on lever? What kind of lever is it?
3Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 4:47 pm
ali2908
ali2908
I presume it's original k100 RS there are faint traces of splines which don't show on the picture.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
4Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 4:52 pm
nino
I dont believe its original. Every K lever has a teeth inside. I think you need proper lever. Even you shaft teeth are damaged it would work with proper lever (if you clean it) Ali, if you dont have any source of used parts at home try Motorworks.
Regards
5Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 4:57 pm
ali2908
ali2908
Do you think there is enough of the splines left for a new lever to get a proper grip
Regards
Ali
1985 K100RS
2002 K1200 RS
6Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 5:02 pm
nino
Its worth to try. Clean it first and try to reshape teeth and chanells with some tool. When mount new lever align it (line on shaft, cut on lever), put 6 mm bolt and tight. I think could be quick and cheap solution.
Regards
7Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 5:07 pm
nino
nino wrote:Its worth to try. Clean it first and try to reshape teeth and chanells with some tool. When mount new lever align it (line on shaft, cut on lever), put 6 mm bolt and tight. I think could be quick and cheap solution.
Regards
You need new lever anyhow, so try cheaper solution.
8Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 6:41 pm
No, Ali that's not an original lever, it looks like an obscure steel lever that someone has bored out to go over the serations and clamped up without any positive location. The original is made of alloy and should look like this:-
Gear lever: am I screwed? Sam_0016
I would try a new/used lever but the serations will need to be cleaned up with a triangular needle file (or a diamond file if they are hardened).
Good luck,
9Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Mon Jul 23, 2012 6:48 pm
ali2908
ali2908
The lever has been welded where the spline part meets the lever so I think you are correct. I have manged to get another lever this evening so will try re-cutting the splines while waiting for it to arrive.
Regards
Ali
1985 K100RS
2002 K1200 RS
10Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Tue Jul 24, 2012 12:04 am
Rjtrucker
I had a shift lever strip out on an old honda I had. I drilled a small hole in between shaft and shifter. Likes keyway. I used a roller pin in the hole and it lasted years .
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
11Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Wed Jul 25, 2012 4:17 pm
ali2908
ali2908
Thanks to everyone, the new lever is on and working fine, just had to file a few new grooves.
Regards
Ali
1985 K100RS
2002 K1200 RS
12Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Wed Jul 25, 2012 4:32 pm
ReneZ
ReneZ
Make sure you fit it with some locktite.
Rene
BMW K100 - 1985 (0030029) Scotland Gear lever: am I screwed? Rain
13Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Wed Jul 25, 2012 4:52 pm
Good result Ali.
14Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Wed Jul 25, 2012 6:31 pm
ali2908
ali2908
Will book the MOT tomorrow.
Regards
Ali
1985 K100RS
2002 K1200 RS
15Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Wed Jul 25, 2012 8:21 pm
Gear lever: am I screwed? Hannib10
In the words of Hannibal...."I love it when a plan comes together!!!"
good work Ali.
88KE
Last edited by 88KE on Wed Jul 25, 2012 8:22 pm; edited 1 time in total (Reason for editing : typo)
Gear lever: am I screwed? Ir-log1188....May contain nuts!Gear lever: am I screwed? Ir-log11
K75RTP - 1994
16Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Thu Jul 26, 2012 1:05 am
It always feel best when the smooth shaft has no teeth marks evident, yet you've made it fit anyway, and you don't feel like you've been screwed.
~Mac McCleary
17Back to top Go down   Gear lever: am I screwed? Empty Re: Gear lever: am I screwed? Thu Jul 26, 2012 4:33 pm
ali2908
ali2908
Test booked for Saturday morning, now I'm really worried!!!!
Regards
Ali
1985 K100RS
2002 K1200 RS
