Top engine bolt wont go in Tue Apr 14, 2015 8:52 pm
touchwoodsden
![touchwoodsden](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
I am fitting the Wasp subframe which is going to have my sidecar hung onto it.
For those who don’t know the subframe, it bulks onto the top engine mountings, the bolts on the side of the sump that take the crash bars on some models and onto the platform which takes the centre on-site stand assemblies.
Fitting has been relatively straightforward but I am having a problem getting the top right-hand engine bolt in, one which is threaded into the lug on the top of the engine block.
Ignore the subframe please because the subframe is only attached to the extremity of the engine.
The lug on the engine and look on the frame are a couple of millimetres out and I just can’t get them into line to get the bolt back in.
I have jacked the engine up which moves them more into line however the frame lug appears to still be a little too far forward.
I have slackened all the other engine bolts off but I still can’t get it in.
It came out without a problem and I have had it in and out a few times before but, when both of the top engine bolts are taken out the engine dropped slightly (couple of millimetres) and that appears to be the problem.
Is this a common problem and does anyone have any ideas?
I have tried slings and ratchet straps around the frame down tube that bolts to the top lug to try to pull it backwards while at the same time jacking the engine up but I just cannot get it to locate in the threaded part of the lug. Will go all the way in but just not catch the threads because it’s just that little bit out.
Is this a common problem and if so does anyone have any ideas?
I’ve tried jacking the engine all over the place but to no avail.
So far, I’ve spent almost 2 hours on this one bolt and I’m tearing my hair out (I didn’t have much to start with!)
Thanks for any suggestions.
