1 undefined oil leak at final drive Sat Mar 20, 2010 10:27 pm
philjw2
Hi there,
I've got a 1986 K100 RT which has just 20,000 miles on the clock. It covered about 13,000 miles in its first 3 years, then around 3,000 in the next 20 years. I bought it in July and have put over 4000 miles on the clock, though most of the time I've had it, it has been stored inactive in a garage. It has recently developed an oil leak, the source of which is not clear. The oil is at the top of the shaft drive (next to where the speedometer impulse transmitter is) down to the final drive drain plug. It only leaks when driven and is depositing oil on the rear tyre and rear brake disc. I've just had the bike serviced (oils changed and valve clearances done) and the final drive drain plug was replaced and fitted with a new seal, however oil is still leaking - though not from the drain or filler plugs (as far as I can tell anyway). The shaft itself does not seem to be weeping oil. Is it possible that oil is leaking out of the rear shock? The rear shock is the original one. I can't think of alternative source for the oil.
Philip
Philip
