1Back to top Go down   Throttle bodies Empty Throttle bodies Tue Dec 20, 2016 1:16 pm
smoll1
Hi all.
My throttle bodies bing number 95/34/401 are worn out.
I have spare set that I got few years ago in a job lot of parts, but the bing number stamped on them is 95/34/403. Does anyone know if these would work? What do the differences in the part number mean?
They look the same
The bike is k100rs 1987.
Hopefully someone will know
Smoll Very Happy Very Happy
2Back to top Go down   Throttle bodies Empty Re: Throttle bodies Tue Dec 20, 2016 2:17 pm
BobT
BobT
Look up the part numbers on realoem.com and you will see what they were fitted to.
3Back to top Go down   Throttle bodies Empty Throttle bodies Tue Dec 20, 2016 6:31 pm
smoll1
Hi
Yea I looked at part no. on fiche, but the only number I can see is the bing number not a bmw part number.
It's a weird one I have to admit as most seem to be the 1st no. I posted.
Regards
Smoll
4Back to top Go down   Throttle bodies Empty Re: Throttle bodies Wed Dec 21, 2016 4:43 am
type/size/model
Type 95 were used on the K-series.
Size 34 is the internal dia of the TB. They were also made in 38mm which I'm guessing were used on the 1100 maybe.
Models should be interchangeable. I'd guess the 403 is a later version.
BING
 Throttle bodies Austra12    Fuel:  95 Octane
5Back to top Go down   Throttle bodies Empty Re: Throttle bodies Wed Dec 21, 2016 5:25 am
BobT
BobT
38mm = K100 16 valve?
6Back to top Go down   Throttle bodies Empty Throttle bodies Wed Dec 21, 2016 11:08 am
smoll1
Ok thanks
I guess as you say the 403 later version. They are in good condition, compared to old ones which are corroded badly.
I will put them on. I looked on parts fiche and part number for 8 v k100 appear same.
If I get any issues I will let you know.
Thanks again
Smoll
7Back to top Go down   Throttle bodies Empty Re: Throttle bodies Wed Dec 21, 2016 4:53 pm
k-rider
k-rider
i think the 8v k100 tb's meassure 33mm internal dia .
the 16v k100/k1100 tb's meassure 35mm internal dia
and finally the 38 mm is for the k1200
k-rider
8Back to top Go down   Throttle bodies Empty Re: Throttle bodies Thu Dec 22, 2016 8:32 am
If you can get K1100 TBs then fit those instead of replacing the OEM K100 TBs. Advance the timing by six degrees and you have a whole new herd of low-down horses. On a back-to-back test it makes a standard K100 feel like a hungover slug. Well, maybe not that bad but there is a distinct difference between the modified and non-modified bikes.
9Back to top Go down   Throttle bodies Empty Re: Throttle bodies Thu Dec 22, 2016 10:03 am
Motorbike Mike
Motorbike Mike
I had 1100 TB's on a 1000 8v and they worked just fine. I've got 1200 TB's on an 1100 and they work great too.
They all seem to work well choose which set you fit.
Advancing the ignition timing IS well worth the effort-it's worked every time for me. Don't be afraid to experiment, the worst case scenario is you swap some parts back again and all you've lost is a little bit of enjoyable fettling time. Win-win situation!
10Back to top Go down   Throttle bodies Empty Throttle bodies Thu Dec 22, 2016 10:12 am
smoll1
Very true. I will try it and see what happens Very Happy
