1Back to top Go down   Main ABS I Relay  Empty Main ABS I Relay Sun May 23, 2021 8:27 pm
doktor33
doktor33
Hi,
I still haven't solved my ABS problem (https://www.k100-forum.com/t16942-k75-rt-abs-ecu-error-7). I think I will have it fix.
However, I noticed the main ABS relay (I have a ABS I) does not click anymore. Alone, it works. Do you have any "simple" solution to check the wire ? Not eaasy to follow the wire and I just need to know where the wire comes from and where it goes without disassembling everything !
Of course, with an ECU which may not be ok, the relay problem may be linked. But I need to eliminate each hypothesis.
Thanks for your help !
http://k75rt.wordpress.com
