Engine doesn't turn over Sun May 23, 2021 4:26 pm
Gergely
I am struggling for 3 month with no solution. After 3 weeks sitting the bike does not started. Starter motor was (is) not able to turn so not turns over the engine. After changing battery starter relay and 2 starter motors, no improvements. Now I am trying only with direct cable to starter motor from auxiliary 100% charged battery and starter motor spins maximum only for 1 second (like half rotation of the engine) and stops. Turns over only with sparks out. I dismantled engine completely and checked moving parts, pistons - moving free and easily, camshafts are OK, I cleaned valves and all the internal parts of the engine ò long job. No difference. The only thing is that it is very hard to turn the rear wheel by hand in 5th gear (and almost impossible in lower gears). So even bump start fails. Someone with same symptoms? thanx Greg
K75 1991
