2 Re: Final Drive Splines Thu Jul 01, 2021 2:55 am
Looks new to me
K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3 Re: Final Drive Splines Thu Jul 01, 2021 3:29 am
The teeth of the splines on the drive shaft have a small amount of wear and the drive unit looks quite good, so slop some moly grease(at least 50% moly) and shove them back in.
4 Re: Final Drive Splines Thu Jul 01, 2021 8:07 am
+1 on RickG's reply. When looking at the splines look at the top, it should be nice and wide and flat. From the end, they should have a trapezoidal shape, wear is indicated when they start to look triangular at the end.
Many of us use Hondamoly lube on our splines. The current version is 70% molybdenum. I lube my splines with it once a year, and they have held up very well. My K75RT is closing in on 100,000 miles and the splines still look new.
BTW, grab the end of your drive shaft with vise grips and give it a good yank to pull it out of the swingarm so you can lube the front end and check the universal joint for stiffness and notching in it's motion. Normally, the splines at the front end don't wear, but as long as you are in there, it's a good idea to show them a little love.
5 Re: Final Drive Splines Thu Jul 01, 2021 8:40 pm
bmwk100rs
@Arlina, @RickG, and @Point-Seven-five
Thank you for confirming the condition and the suggestions. Regarding lube, have you used the Castrol Molub-Alloy Paste White T as lube for the splines before or should I just stick with Staburags NBU 30?
6 Re: Final Drive Splines Thu Jul 01, 2021 9:00 pm
The white paste has been superseded by the silver paste Molub-Alloy Paste TA. BMW part No 18 21 9 062 599.
7 Re: Final Drive Splines Thu Jul 01, 2021 9:19 pm
bmwk100rs
MartinW wrote:The white paste has been superseded by the silver paste Molub-Alloy Paste TA.
MartinW,
Let me see I follow. Are you saying that the Molub-Alloy Paste TA superset Molub-Alloy Paste T, which both are better than Staburags NBU 30? If so, then I'm glad you pointed that out since I didn't what was the difference between the T vs the TA. Thanks!
8 Re: Final Drive Splines Thu Jul 01, 2021 9:50 pm
Everyone seems to have their favourite. I think that as long as it has a high moly content 50%+ and you lube at least every rear tyre change you're fine. I've had my Brick for 20+ years and 178,000 K's and until the Castrol white T was superseded by the Silver TA I used it, I'm now using the silver TA.
9 Re: Final Drive Splines Fri Jul 02, 2021 11:14 pm
bmwk100rs
Point-Seven-five wrote:grab the end of your drive shaft with vise grips and give it a good yank to pull it out of the swingarm so you can lube the front end and check the universal joint for stiffness and notching in it's motion. Normally, the splines at the front end don't wear, but as long as you are in there, it's a good idea to show them a little love.
@Point-Seven-five,
I remove the swing case to better yank the shaft, but I still cannot pull it out. Is there any clip that I need to remove first?
10 Re: Final Drive Splines Fri Jul 02, 2021 11:37 pm
There is an internal snap ring so just give it a solid jerk and it will come off, be sure to seat it back when replacing it.
11 Re: Final Drive Splines Sat Jul 03, 2021 1:11 am
bmwk100rs
RicK G wrote:give it a solid jerk and it will come off..
Got it out. Thanks RicK G!
12 Re: Final Drive Splines Sat Jul 03, 2021 1:28 am
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Final Drive Splines
Similar topics
