1Back to top Go down   Moisture on splines Empty Moisture on splines Mon Dec 05, 2022 6:48 am
tinyspuds
tinyspuds
Put a new rear tyre on so lubed shaft splines as usual. The previous application of moly looked to be carry more moisture than I’ve seen before, was a thick slime rather than the normal paste consistency. I’m going to redo it, (degrease  the shaft splines completely and do the best I can with the counterpart fitments, then re-moly.
I’ll check the boot for water ingress, but any other thoughts?
TIA, Stu
2Back to top Go down   Moisture on splines Empty Re: Moisture on splines Mon Dec 05, 2022 9:27 am
What lube were you using that turned to "slime"?  Did you do both ends of the shaft?  Does the "slime" smell like transmission lube/gear oil?
3Back to top Go down   Moisture on splines Empty Re: Moisture on splines Mon Dec 05, 2022 10:55 am
tinyspuds
tinyspuds
Castrol Molub-Alloy Paste White T. Should be sound. I may have used to much the time before. I did do both ends, both came out the same.
 I’ll have a sniff when I get the shaft out.
Edited: PSF I guess you’re thinking potential output shaft seal leak. Which is a v.good thought, I assumed a water mix. Lets see what I find.
