Instrument cluster lights Wed Jan 25, 2023 3:14 pm
brianpen
I replaced the odometer gears on my 94 K75 and all went well. Also replaced the backlight bulbs with led's. Everything appears neat and tidy, and I was careful with the ribbon installation, but the backlight bulbs won't light; although the brake, abs, high beam bulbs all work at the turn of the key.
The backlights are supposed to work at the turn of the key, correct? Is there perhaps an easy explanation, or test I can do? Is there a particular connection that may be the culprit?
If it were only one or two of the four led's I could understand a bad connection, but not all 4.
