Won't start & now it won't stop Wed Feb 09, 2011 4:49 am
Ramadge
Hi guys
I am having a problem on my 89 K75s. Bad starting etc. Eventually traced it down to a bad connection from the battery positive terminal (good at the terminal, but bad about 2 inches down which was covered with insulation tape). Fixed that, but it created another problem. Started first time, but the starter motor doesn't turn off (even with the key out and the kill switch in off position). Indicators and horn don't work either. Checked the Starter Relay since I have heard this is often the problem if it sticks. Relay is fine, can see it going on and off when i hit the starter button. But problem persists. Any ideas? I thought perhaps the starter motor itself, or the load sharing relay (but these are just the first 2 that come to mind). It's been quite a while since I did fault diagnosis on a BM (back in the 70s when the electronics weren't as sophisticated as they are on a late 1980s bike.
Ramadge
Ramadge
