Temperature sensor Sun Mar 31, 2024 5:07 pm
davemadsen
![davemadsen](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
1987 K100RT. I’m trying to assess if the temperature sensor is working properly. In reading various threads, I believe I should expect about 2.4k ohm resistance between pins 10 and 13 at the FI module. Please verify if I should be testing the CONNECTOR or the MODULE. I would think it has to be the connector inasmuch as without the connector attached, the FI module is just a magic box buried beneath a bunch of wires without any connection to anything. Checking resistance between connector pins 10 and 13 I get a reading of 1.016k ohms at 61°F/16.7°C which seems far enough out of spec to warrant replacing the sensor. Thoughts?
Also, my reading led me to think pin 13 is a ground, but I get 1.01k ohms between pin 13 and frame ground (as measured from the connector, not the FI module). I am pretty diligent about keeping all grounds in good order, so I am wondering if the ground between the temperature sensor and the coolant pipe might be compromised. More thoughts?
Dave
Dave
Dave
