I need a workaround to replace my fuel sender on a 85 K100RT Mon Apr 15, 2024 6:57 pm
BubbaLinks
![BubbaLinks](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![New member New member](https://2img.net/i/itest/ranks/default/default1.gif)
It's the under tank screw on one, not the 4 bolt one with the float. I have the nut left behind after the plastic broke off as well as the 4 pin connector. I need a way to seal the hole and run the wiring through it. My first thought was to find a threaded cap and drill a hole to run the wiring through but I haven't been able to find the correct cap size and threading. Another thought was to bond a plastic washer to the existing nut, run wiring through. Or possible weld the hole shut and find some other way to run wiring into the tank. This is a first for me so any help would be much appreciated! ![I need a workaround to replace my fuel sender on a 85 K100RT Img_1210](https://i.servimg.com/u/f94/20/55/93/51/img_1210.jpg)
![I need a workaround to replace my fuel sender on a 85 K100RT Img_1211](https://i.servimg.com/u/f94/20/55/93/51/img_1211.jpg)
