1Back to top Go down   Gaskets Yes/No Empty Gaskets Yes/No Fri Mar 04, 2011 4:22 pm
jwh01
Hi all,
Could anyone tell me if there is a engine gasket between the gear box and the bell section as there was not one there when I parted the two parts. I would have thought rain/water could get in to the clutch area without it. I cant find one in the moto-bins or Motorworks sites. Should it be a sealant that should be there.
Thanks John
2Back to top Go down   Gaskets Yes/No Empty Re: Gaskets Yes/No Fri Mar 04, 2011 5:17 pm
japuentes
japuentes
Hi there
No gasket, its an structural joint, the engine/gearbox unit gives the stiffnesess to the tubing frame. Must be very carefull with the mating surfaces, and the guides (locating dowells) are a must to assure correct gear/engine alignment.
Best regards
JAP
