1 ENGINE DIES, WILL NOT START ignition lights dull Fri 01 Jan 2010, 09:49
viney
Hey guys
I have a problem with my 86 K100Rt and after reading a few threads here it sounds like it could be many many reasons for this happening. But first... the symptoms....
problem in detail:
this regularly occurs at starting
often i will try to start the bike and when i hit the start button all the ignition lights will turn dull (kinda like a flat battery) when i try to start it the fuel pump will start and i might get 1 turn from the starter or nothing at all (it depends)... if i flick the kill switch and set it back to normal (do you call this cycling?) it might start but often I need to do this 4 or 5 times or more until i can get the starter to engage long enough to get the bike started. if i don't flick the kill switch again after a failed start the starter will not engage at all when i hit the start button (only the fuel pump will start but nothing from the starter).
also the following has happened a few times which is a worry... if i am in traffic i would hate for it to happen so gotta get this sorted ASAP
Yesterday i was cruising in 3rd gear on a quiet suburban street after grabbing some supplies and the bike stopped for no apparent reason. It has happened a couple of times before on gear changes and i was unsure if it actually happened or not if you know what i mean... when i came to a stop I hit the start button and the starter cranked hard but the engine would not fire.. didnt have tools on me to pull out a plug so can't tell you any if they were wet or not.
this weekend i will pull the tank off and check the temp sensor and earths and all connections that i can find. I am thinking a bad earth may be the most likely suspect but will wait to see what we find. I also think this may be 2 separate problems
if anyone else has had the same experience feel free to let me know, otherwise i will update you as to what i find.
viney
problem in detail:
viney
