1Back to top Go down   Spline lube/driveshaft Empty Spline lube/driveshaft Wed Jan 22, 2014 8:35 am
troubleshooter
troubleshooter
Have watched all the youtube vids and scoured the forum - but just want to check!
It look like once you have removed the rear drive to lube the spline the driveshaft "pulls out" with a tug to grease/inspect both ends of the drive shaft. Does it "pop back in" in the same way without having to remove the swing arm?
Thanks, Mike
2Back to top Go down   Spline lube/driveshaft Empty Re: Spline lube/driveshaft Wed Jan 22, 2014 9:13 am
MikeP
MikeP
Yes. There is a circlip that you need to overcome, it doesn't need a great deal of force and you'll know from the 'click' when it goes back that it's fully seated.
1992 K1
3Back to top Go down   Spline lube/driveshaft Empty Thank you! Wed Jan 22, 2014 4:19 pm
troubleshooter
troubleshooter
Very Happy
4Back to top Go down   Spline lube/driveshaft Empty Re: Spline lube/driveshaft Fri Jan 24, 2014 2:41 am
zonenfeile
zonenfeile
its easy to check isf the shaft is in correct position
mount it - than a slight clap with the rubber hammer - click
correct pos: the rear end of the shaft is 10mm longer than the plane surface of the rear fork
finished
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
5Back to top Go down   Spline lube/driveshaft Empty Re: Spline lube/driveshaft Fri Jan 24, 2014 10:38 am
Johnser
Johnser
I replaced the spring clip on mine as it had broken. It was pretty hard to get back on and off again the next time I removed. Had to do some serious gripping/levering to get it out. Geoff Capes wouldn't have tugged it out by hand.
