1 Clutch cable replacement. Tue 30 Mar 2010, 04:02
Rickmeister
G'day,
I have only just registered on this K site, on the advice of Ned, from Sydney, Australia. Excellent reading!
I have just now replaced my clutch cable (1991 K100, ex-police, 70,000Km). The handbook says that the length of the exposed inner cable at the clutch end is to be 75mm, and then to adjust the clutch operating shaft for the correct amount of free play at the clutch lever end.
My question is: why is the length of the exposed inner at the clutch end specified with such a tight tolerance? My mind tells me that the travel of the inner cable when the clutch lever is pulled in is a fixed amount, irrespective of the amount of exposed inner. As long as there is the required amount of free play (0.1") the clutch adjustment should be OK.
Any comments?
Thanx,
Rick G.
Any comments?
Thanx,
Rick G.
