Topics [0]
Problems with starting....by twincarb | 25 | 2179 | Mon Aug 13, 2012 10:56 am by twincarb |
Intermittent speedo failureby KlaustheKStock speedometer on my 87 RS cuts out | 4 | 1793 | Sat Aug 11, 2012 2:47 pm by KlaustheK |
85 K100 injectorsby tdkclydes | 19 | 6653 | Thu Aug 09, 2012 6:52 pm by club_c |
Odometre gears availability in Australia.by dalderton | 13 | 2145 | Tue Aug 07, 2012 7:24 pm by RT |
Gear position switchby giles4060 | 13 | 2098 | Thu Aug 02, 2012 11:47 pm by Rjtrucker |
Wiring to the Coils...by twincarb | 3 | 1899 | Tue Jul 31, 2012 2:36 am by twincarb |
Starter wiring connection...by twincarbjust putting my mind to rest more than anything else... | 16 | 3825 | Sun Jul 29, 2012 1:57 pm by ReneZ |
K100RS Oil Pressure Switch Cable unhook? Maybe I'm daft. [SOLVED]by TSBT | 9 | 4737 | Sun Jul 29, 2012 11:26 am by TSBT |
Sparkplugs aren't firing on my RS...[SOLVED]by TSBT | 6 | 2377 | Sun Jul 29, 2012 10:53 am by TSBT |
Calling UK South West ABS owners..by twincarb | 13 | 1615 | Fri Jul 27, 2012 9:20 pm by Rick G |
Backfire on K100RS 16vby mr grumpy | 10 | 2257 | Fri Jul 27, 2012 4:43 pm by mr grumpy |
Does a K1100 alternator fit a K100?by STEVE1959 | 5 | 2229 | Thu Jul 26, 2012 6:41 pm by STEVE1959 |
Weird Motronics behaviourby mfranks | 7 | 1455 | Wed Jul 25, 2012 5:40 am by mfranks |
Fast and easy elimination of metal noise from exhaust shieldby nino | 19 | 2209 | Tue Jul 24, 2012 7:15 am by K75cster |
Another request for helpby AjaysElectrix | 3 | 1425 | Sat Jul 21, 2012 4:25 am by Ajays |
K75RT dies during the nightby Peter_SkovCan't start, no power (not enough) | 18 | 1687 | Fri Jul 20, 2012 6:16 pm by K-BIKE |
Dielectric Grease?by walker | 12 | 2673 | Thu Jul 12, 2012 8:37 pm by Ned |
[solved]Really messed up a coil on my 85 K100by phoenixk2bWhile cleaning the coil it slipped out of my hands, dropped about 8" | 18 | 2994 | Wed Jul 11, 2012 11:53 am by Rjtrucker |
[Solved] Non starting 92 K100LT[ 1, 2, 3 ] by 92KK 84WW OlafProblem starting, not battery | 123 | 5851 | Mon Jul 09, 2012 6:22 am by captaink |
Headlight relayby twincarbIt's one of them again | 5 | 1983 | Sun Jul 08, 2012 11:06 pm by robmack |
simple fix for a complex problemby diversity48 | 4 | 1610 | Sat Jul 07, 2012 9:01 pm by diversity48 |
What's the green wire do?by Lucky Louchasing gremlins | 12 | 1808 | Sat Jul 07, 2012 4:53 am by Lucky Lou |
Dead K ?by davebElectrical gremlins | 18 | 1843 | Fri Jul 06, 2012 7:58 pm by K-BIKE |
Help please: Starting issueby dennisg84485 K100RT | 48 | 3076 | Thu Jul 05, 2012 3:29 pm by dennisg844 |
Digital insturment panel, aftermarketby rwiley111Converting from the brick insturments to a small digital readout | 1 | 1645 | Tue Jul 03, 2012 12:43 pm by Inge K. |
abs removalby ridefarabs dash light stays on | 16 | 4713 | Sun Jul 01, 2012 7:07 pm by ridefar |
A few problems here, 1985 german K100, engine cut out, mileage, noises, etcby Rabidchiwawa007k100 problems | 18 | 5760 | Thu Jun 28, 2012 1:42 pm by Rabidchiwawa007 |
RS 4 Valve (1991) Coil resistanceby giles4060 | 8 | 1477 | Thu Jun 28, 2012 6:46 am by Inge K. |
does any one know where this fits pleaseby paulang007steel braeded wire no covering a foot long has 2 spade connectors and 1 loop connector for bolt | 23 | 1577 | Wed Jun 27, 2012 1:33 pm by paulang007 |
Non-original ventilator fan replacement by BOSCHby ffbikersaCan't find where I saw it | 2 | 1449 | Tue Jun 26, 2012 2:28 pm by ffbikersa |
indicatorby petrichbright indicator kills the 15A FUSE.. | 1 | 1423 | Mon Jun 25, 2012 8:01 am by charlie99 |
Starter brushes replaced and bike starts right away, BUT new oil leakby mack88821991 K100RS | 10 | 1866 | Fri Jun 22, 2012 1:01 pm by charlie99 |
Electrical Problemsby Tom GEngine cuts out,ignition lights dim,headlight stays on bright. | 13 | 2156 | Thu Jun 21, 2012 4:02 am by Tom G |
Speedometer needle shaft brokenby greenmachine61K100RS-89 16VABS | 15 | 3045 | Wed Jun 20, 2012 12:43 am by Two Wheels Better |
[solved]Help with New to me 85 k100 starter running while battery is hooked upby phoenixk2bBike started then wouldn't start, now starter just runs, with kill switch and key in off position | 14 | 3989 | Tue Jun 19, 2012 2:54 pm by Two Wheels Better |
Dash Speakersby CanberraDave | 3 | 1750 | Sun Jun 17, 2012 6:34 pm by ReneZ |
Where would this cable go?by ianburgess | 2 | 1299 | Sat Jun 16, 2012 10:50 pm by ianburgess |
Starter helpby mack88821991 K100RS | 6 | 1646 | Fri Jun 15, 2012 2:50 pm by mack8882 |
1984 K100RT - possible electrical issue ?by kramboAdvice welcomed | 35 | 2907 | Thu Jun 14, 2012 8:10 am by Mi Amigo |
Ignition Switchby Jumpmaster | 7 | 4489 | Mon Jun 11, 2012 9:18 pm by Rick G |
Electrical diagrams upgradeby Crazy Frog | 28 | 2503 | Mon Jun 11, 2012 6:25 pm by ali2908 |
Right signalby BooG | 7 | 1465 | Fri Jun 08, 2012 5:44 pm by K-BIKE |
"CHOKE" LIGHTby RSMITH | 19 | 3371 | Thu Jun 07, 2012 5:44 pm by RSMITH |
Speedo issue...by Schatzi03 | 1 | 1368 | Sun Jun 03, 2012 2:49 pm by Crazy Frog |
89 K 100 LT ventilator fan not startingby ffbikersaWhich side fairing needs removing? | 13 | 2020 | Thu May 31, 2012 11:19 pm by ffbikersa |
Starting problemsby hesperian-tumbleweedNon starting, no indicators, no horn, no headlight | 16 | 3153 | Thu May 31, 2012 10:13 pm by krambo |
K100RT Temperature Sensing Switch Unitby quantechK100RT Temperature Sensing Switch Unit has Dead shorted | 22 | 4243 | Thu May 31, 2012 3:52 pm by charlie99 |
Fuel pump intermittently working.by ffbikersaTroubles when starting | 7 | 1697 | Thu May 31, 2012 3:48 am by ffbikersa |
91 K100RS electricial system shutdownby jumper2001Intermittent problem now seems to be permanent! | 8 | 1772 | Wed May 30, 2012 11:11 pm by charlie99 |
No Current at Injectorsby roddawNeed Help Please. | 12 | 1593 | Wed May 30, 2012 10:25 am by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
