Topics [0]
Fast idle after fan startsby nino | 13 | 938 | Mon May 10, 2021 8:05 am by Laitch |
Relay fuse box for a cafe racer cleaner lookby brunodequeirozIs it doable? | 4 | 954 | Mon May 03, 2021 10:05 am by Suzi Q |
Replacement Keyby moriarti | 10 | 1616 | Fri Apr 30, 2021 3:05 pm by Point-Seven-five |
['93 K75] Temp sensor relay wiring?by roach374 | 20 | 1833 | Thu Apr 29, 2021 3:02 pm by Laitch |
No power to fuel pumpby laxer | 31 | 2336 | Thu Apr 29, 2021 2:15 pm by Guest |
Welded gastank and now the pump won't startby Carlsen | 11 | 865 | Mon Apr 26, 2021 3:29 pm by 92KK 84WW Olaf |
Light to gaugeby Carlsen | 4 | 822 | Sat Apr 24, 2021 11:03 am by moriarti |
Setting for acewell 2853 wired with bep 3.0by ShibboletFor those who have a Acewell 2853 with bep 3.0 | 2 | 1124 | Mon Apr 19, 2021 6:16 am by Shibbolet |
knackered knutsby moriartinothing lasts forever | 0 | 608 | Fri Apr 16, 2021 12:39 pm by moriarti |
Well, erm.. this is embarassingby Bonzo | 5 | 878 | Sun Apr 11, 2021 4:00 am by Bonzo |
rough running 16v K100 tpsby warmshed | 5 | 912 | Fri Apr 09, 2021 4:23 am by warmshed |
ECUs never fail...by Suzi Q | 23 | 3431 | Thu Apr 08, 2021 3:34 am by tinyspuds |
Shorai Lithium Ion battery on a ’93 K1100rs?by WDB90 | 14 | 1209 | Wed Apr 07, 2021 10:13 am by Laitch |
Will the radiator fan turn on without a coolant bulb?by nullfox | 2 | 721 | Wed Mar 31, 2021 5:19 pm by Dai |
['93 K75] ICU pinout question?by roach374 | 6 | 1020 | Sun Mar 28, 2021 8:18 pm by roach374 |
K100 RS 16V ECUby Guest | 21 | 4508 | Sun Mar 28, 2021 1:28 pm by Guest |
['93 K75] Fuel injector wiring question?by roach374 | 3 | 873 | Sun Mar 28, 2021 12:22 pm by roach374 |
K100RS 16V ECU Compatibilityby GuestPossibility of fitting other ECU from other model k100? | 11 | 1240 | Wed Mar 24, 2021 7:30 am by Guest |
starter circuit problem[ 1, 2 ] by stevieboy63starting issues after refitting frame, post powder coating | 54 | 2404 | Thu Mar 18, 2021 8:21 am by stevieboy63 |
Wiring aftermarket handlebar switchesby zedtillimded | 3 | 1865 | Tue Mar 16, 2021 2:54 am by Wiz |
3 unknown connectors?by JiiPee63 | 10 | 1155 | Sat Mar 13, 2021 10:32 am by JiiPee63 |
Copaslip/anti-seize on spark plugs - or not?by Bonzo | 12 | 1108 | Tue Mar 09, 2021 7:10 pm by Point-Seven-five |
K75 Alternator rubber bushesby GrahameCan't undo two of the alternator bolts | 5 | 813 | Thu Mar 04, 2021 1:15 pm by Grahame |
[1993 K75] Trouble reading wiring diagram: How do the clutch and gear switches stop the bike from starting?by roach374 | 9 | 1504 | Sat Feb 27, 2021 9:24 am by Laitch |
diagnostic fault code.by warmshed | 11 | 1580 | Wed Feb 24, 2021 1:26 pm by warmshed |
K 75/100 Instrument Pod Gasketby jjefferiesPart is discontinued or NA | 6 | 771 | Mon Feb 22, 2021 2:50 pm by jjefferies |
Pressure Relief Valve Testingby AUBIEBMWTesting the Pressure Reliev Valve - How To? | 6 | 873 | Wed Feb 17, 2021 5:17 am by daveyson |
86 K100 Weird temp sensor issue?by Dustydogs | 9 | 1017 | Tue Feb 16, 2021 4:12 am by Dustydogs |
K75 Weak/No Sparkby RetroRebuilds | 9 | 1079 | Sat Feb 13, 2021 7:36 am by RetroRebuilds |
Performed ABSectomy, now starter won't spin engine over??by GrayRiderElectrical problems | 2 | 701 | Thu Feb 11, 2021 3:32 pm by GrayRider |
Another K75 Gremlinby jjefferiesBike wouldn't shut down. | 8 | 1132 | Mon Feb 08, 2021 3:09 pm by Bruce Petterson |
Fuel pump relay troubleby Beemer WheelerNo ground found on pin 86 | 19 | 2439 | Mon Feb 08, 2021 2:07 pm by Beemer Wheeler |
Heated clothing - direct into socket?by Bonzo | 15 | 1471 | Mon Feb 08, 2021 6:08 am by Dai |
Battery Tenderby Colin Press | 17 | 1080 | Tue Feb 02, 2021 1:38 pm by Point-Seven-five |
diagnostic plug for 16v K100by warmshed | 18 | 1496 | Sat Jan 30, 2021 7:40 pm by Dai |
An interesting K75 Electrical Gremlinby jjefferiesChasing a headlight issue K75 | 22 | 1457 | Sun Jan 10, 2021 7:19 pm by robmack |
1986 BMW oem optional fog lights install questionby lefthanderEarly K model Oem optional fog lights | 14 | 2453 | Sun Jan 10, 2021 7:17 am by charlie99 |
Unconnected connectors / fuse box ?by JiiPee63 | 6 | 1063 | Sun Jan 10, 2021 7:16 am by charlie99 |
BMW K100 Coil Ohm Valuesby cyclemanBMW K100 Coil Ohm Values | 6 | 1894 | Tue Jan 05, 2021 9:10 am by cycleman |
K75 Alternator part numbers?by roach374 | 9 | 1063 | Sun Jan 03, 2021 1:35 pm by Point-Seven-five |
Realm Engineering HT leads[ 1, 2 ] by Snod Blatter | 62 | 6323 | Sun Jan 03, 2021 12:22 pm by Snod Blatter |
K75 Clock always on: Is this normal?by roach374 | 5 | 1140 | Sat Jan 02, 2021 11:02 am by cycleman |
BEP + Cheap eBay Speedo RPM/Speed Problemby nullfox | 0 | 1019 | Fri Jan 01, 2021 4:10 pm by nullfox |
Fitting replacement HESby Dai | 3 | 916 | Wed Dec 30, 2020 5:12 am by Dai |
K75/K100 Instrument Pod LED'sby jjefferiesSearching for proper LED's for Instrument POD | 8 | 1026 | Tue Dec 29, 2020 8:24 am by Point-Seven-five |
alternator noise/rubbersby 75acnoise from r/h side of engine | 3 | 1051 | Mon Dec 28, 2020 5:01 pm by Arlina |
battery drainby brickrider2K1100LT battery | 13 | 1154 | Wed Dec 23, 2020 6:24 pm by brickrider2 |
Sequential Indicators easy conversion. Not so easy but solvedby MartinW | 12 | 1740 | Mon Dec 14, 2020 5:48 pm by MartinW |
Fuel pump fuse blowsby brianpenK75 | 6 | 1032 | Sun Dec 13, 2020 8:18 am by moriarti |
Flashing bulb monitor dash light. 91 K75sby MartinW | 12 | 1246 | Thu Dec 03, 2020 5:53 am by MartinW |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
